Welding Journal
Jump to:
Aluminum Q&A
June 2025
Q: Can aluminum be welded with resistance welding processes, such as resistance spot welding? I have used resistance spot welding on steel very successfully; can I use it for aluminum?
A: Resistance welding is defined as follows: a group of welding processes producing coalescence of the faying surfaces with the heat obtained from the resistance of the workpieces to the flow of the welding current in a circuit of which the workpieces form part and by the applicati..
Already a member? Log In
Publication Archive
